Results 1 to 18 of 18
    Sep 2019
    Philly
    28
    Looking to get my slash running again.
    I blew the stock brush motor in my slash 4x4! Iím looking to upgrade now to brushless been checking out hobbywing and wanted to know.
    Will this set up work for my slash and what else would I need if anything to put it in and working?
    Mar 2016
    1,345
    It should serve you well
    Go for it
    fabricator
    RC Qualifier Calebs0615's Avatar
    May 2020
    Maine
    795
    Im following this. I also am in the market for a new motor and esc for my slash. I stole the vxl stuff for my rustler
    Sent from my LGL722DL using Tapatalk
    Also, if you use traxxas batteries you might have to install new connectors. Cause i dont know if those come with one at all.
    Sep 2019
    Philly
    28
    Iíll be getting new batteries. I didnít think about it but Iíll just try to find the ones with that connection. Thanks!
    RC Qualifier RCWilly's Avatar
    Feb 2019
    California Bay Area
    800
    I am also thinking of a new combo for my Slash 4x4. Since I got it as a used roller a couple of months back, I am just using the old brushed combo from my Slash 2wd (which has the Castle SW4 3800kv). This time, though I think I am going to get a Hobbywing XR8 3600kv.
    Also, Hobbywing ESCs usually don't come with connectors. If they do, it will be XT60 connectors (example: 1080 ESC).
    Sep 2019
    Philly
    28
    Couldnít I just solder and sink wrap connections
    May 2020
    Maine
    795
    Quote Originally Posted by JTin View Post
    Yeah for sure. I think that's the best way to do it. Im not sure how else you would make it waterproof. It probably wouldn't hurt to put a dab of silicone or hot glue so the wraps don't leak.
    103
    Just got this same motor except with the max8 esc which I had the option for traxxas connectors so I wouldnít have to change all my batteries
    Havenít put in yet, Iím waiting on the rustler receiver box (to move it up front)
    Iím thinking itís the same thing as fitting the castle system in my other 4x4
    Sep 2019
    Philly
    28
    This is my firs rc car still very new to hobby had to fix a few things here and there turnbuckles and control arms plastic stuff that breaks from bashing. I miss running itís been down all summer hopping to have it for the winter and lost of snow!! I have the traxxas nicl battery but a lectron pro 2s 7.4V 5200mAh 35C Not sure if it will work with the hobbywing set up or how well itís going to work so I was just gonna get the batteries I need. If your saying there no connector at all for battery?
    103
    Iím saying I had a choice of connector traxxas or deanís
    Not saying that they all come with a choice
    Shop around donít fall for the first one you see
    May 2020
    Maine
    795
    Quote Originally Posted by The Borderdog View Post
    Where did you buy it where they gave you an option to put on the connectors before hand?
    103
    Here it is
    I knew that I had it somewhere
    https://www.aliexpress.com/snapshot/...=4000221187086
    Iím sorry the link doesnít take you straight there
    Just search 2200kv combo and it will give you the option for a T plug or trx plug
    Jun 2014
    San Gabriel, California
    8,474
    JTin: Just remember that the Slash 4x4 (brushed) has different diff gears than the Slash 4x4 VXL (brushless) and you will have to gear up your pinion and spur to compensate (or change your front and rear diffs).
    Brushed diff is 12/47 (3.91 gear ratio).
    Brushless diff is 13/37 (2.85 gear ratio).
    Apr 2020
    NL
    263
    I blew the stock brush motor in my slash 4x4! I’m looking to upgrade now to brushless been checking out hobbywing and wanted to know.
    Won't it be slow on lower voltages (2s/maybe 3s)? Or is 2200kv 'fast' enough?
    It sure looks like a great deal, especialy compared to the stock VXL-3s, wich is more expensive than this, and probably runs wayyyy hotter.
    103
    The 2200kv is not designed for 2s, 3s is ok but not perfect, 4s is the sweet spot and really makes that thing come alive
    Sep 2019
    Philly
    28
    Iíll be getting new batteries this is my first big fix I donít have to have the biggest and baddest just something to get her bashing again.
    Parts came today gonna be going to my local RC store see if they can help me with gearing of diffs
    This combo will not work itís a 1/8 scale motor on a 1/10 scale esc now to contact hobbywing
    Oct 2018
    276
    It can work, I'm assuming the motor has larger bullets? Could change them. But it would be best to get a larger esc. Like the max8
    Sent from my SM-G970U using Tapatalk
    Sep 2019
    Philly
    28
    All good I just ordered EZRUN MAX10 SCT Combo so the motor will match also cheeped then what I got.
