Results 1 to 13 of 13
    Oct 2020
    4
    How to get dirt out of screws ( recommendation )
    My shock fluid ran out so I tried to unscrew the screws to put new shock fluid in but there is dirt stuck in the screws. if anyone has any way how to get dirt out of screw holes on rc car please tell me.
    I have tried using a paper clip and other objects to get it out, doesn't seem to be working.
    14,273
    Air compressor with a rag covering the blow-out so it will not get all over or in your eyes.
    RC Champion RCWilly's Avatar
    Feb 2019
    California Bay Area
    1,000
    Use a toothbrush or something similar. It works pretty well.
    RC Qualifier ElectricPropils's Avatar
    Oct 2020
    Dallas TX
    387
    This works really well ^ though it requires that you have an air compressor with some sort of built in/auxiliary air tank. If you don't (which I find an overwhelming amount of people don't) then you can always use a toothbrush.
    WD40 is pretty good at breaking up dirt, you can spray a little bit on the screw before using some sort of toothbrush/needle to clean it out.
    The present is theirs; the future, is mine.
    RC Qualifier Sp2deSummit's Avatar
    Feb 2019
    Yakima Washington
    433
    I use a big needle, it works pretty well for me:
    I like free stuff!
    Jun 2014
    San Gabriel, California
    8,563
    Needle and air-compressor. WD-40 if necessary.
    Good luck!
    Dec 2003
    Dekalb, IL
    3,490
    I use a small awl to dig around in the screw head a bit to break the dirt up/loosen it, then a puff of canned air. Seems to work very well.
    Aug 2015
    826
    I've used a x-acto knive with a pointed tip to get the dirt loose and most of it comes out. The other suggestions work well for the remainder.
    Oct 2019
    83
    Razor blade, or eye glass flat head. But a good washing often does it.
    RC Qualifier RC Dad's Avatar
    Jul 2019
    Boston
    510
    Quote Originally Posted by ilovetraxxasmax View Post
    I added a couple of dental picks to my tool kit a while back, and they definitely see a lot of use. You can play around with different bevel types, depending on the job. And you won’t have to dull your exacto blades anymore.
    RC Qualifier jdpasl's Avatar
    Dec 2014
    USA
    509
    Xpower air duster is best to blow the dirt away very easily. Easy to carry and just plug in outlet to blow! You can find Xpower air duster on Amazon. I have one and love it! Powerful.
    Sep 2015
    2,348
    Quote Originally Posted by RC Dad View Post
    I agree. Assuming it's hardened in there, dental pick and a little water.
    youtube.com/c/RazorRCvideos
    Jan 2020
    not in an ocean
    256
    I use wire and paperclips to get dirt out of screws.
