My shock fluid ran out so I tried to unscrew the screws to put new shock fluid in but there is dirt stuck in the screws. if anyone has any way how to get dirt out of screw holes on rc car please tell me.
I have tried using a paper clip and other objects to get it out, doesn't seem to be working.
Air compressor with a rag covering the blow-out so it will not get all over or in your eyes.
Use a toothbrush or something similar. It works pretty well.
This works really well ^ though it requires that you have an air compressor with some sort of built in/auxiliary air tank. If you don't (which I find an overwhelming amount of people don't) then you can always use a toothbrush.
WD40 is pretty good at breaking up dirt, you can spray a little bit on the screw before using some sort of toothbrush/needle to clean it out.
The present is theirs; the future, is mine.
I use a big needle, it works pretty well for me:
I like free stuff!
Needle and air-compressor. WD-40 if necessary.
Good luck!![]()
I use a small awl to dig around in the screw head a bit to break the dirt up/loosen it, then a puff of canned air. Seems to work very well.
https://www.youtube.com/c/olds97lss
I've used a x-acto knive with a pointed tip to get the dirt loose and most of it comes out. The other suggestions work well for the remainder.
Sent from my VS996 using Tapatalk
Razor blade, or eye glass flat head. But a good washing often does it.
Xpower air duster is best to blow the dirt away very easily. Easy to carry and just plug in outlet to blow! You can find Xpower air duster on Amazon. I have one and love it! Powerful.
I use wire and paperclips to get dirt out of screws.
