Results 1 to 12 of 12
    Nov 2020
    Question Broken Stampede VXL
    I wrecked this car and the driveshaft broke wondering what part number I need to buy to fix please help I’m new SEE ATTACHED VIDEO FOR EXPLANATION
    https://youtu.be/ISCAF-2p1pQ
    Rotterdam, Netherlands
    8,641
    It seems you mean this one: https://traxxas.com/products/parts/6837
    You can check the exploded views to find the numbers of the parts: https://traxxas.com/explodedviews/St...Front-Assembly
    RC Qualifier ElectricPropils's Avatar
    Oct 2020
    Dallas TX
    387
    Very helpful Petertje60, I couldn't have done better myself.
    The present is theirs; the future, is mine.
    Apr 2015
    Tinley Park, IL
    352
    The stock drive shafts are ok, but due wear quickly.
    Traxxas make some decent steel shafts if you are going to run a lot or if you run 3S. They cost a bit more than plastic but should run for years with normal use.
    RC Champion RCWilly's Avatar
    Feb 2019
    California Bay Area
    999
    It looks like a Stampede 2wd. Driveshafts connect the gearbox to the wheels and spin the tires, so the front does not have any driveshafts. Petertje60 was right that the steering block broke, but the link posted was for the 4wd version: https://traxxas.com/products/parts/3736
    If you want a stronger part, you could get ones in aluminum (they come in blue, green, and red): https://traxxas.com/products/parts/3636A
    Jan 2020
    The Moon
    163
    Quote Originally Posted by RCWilly View Post
    RCWilly is right. it is a 2wd model. Instead of the Aluminum Steering Blocks, you could also get the cheaper rpm option.
    https://www.rpmrcproducts.com/shop/a...-stampede-2wd/
    RC Qualifier Calebs0615's Avatar
    May 2020
    Maine
    891
    I wasnt a fan of the rpm stuff i bought. The material is way too soft.
    Sent from my LGL722DL using Tapatalk
    Jan 2020
    The Moon
    163
    Quote Originally Posted by Calebs0615 View Post
    That's the point. Its made of 100% nylon I think. that way it flexes instead of breaking in a crash.
    Jan 2020
    not in an ocean
    256
    I like rpm parts, never had one break. Also a lot cheap than aluminium.
    Feb 2019
    California Bay Area
    999
    Traxxas aluminum parts are made of 6061-T6 aluminum, which is an alloy between aluminum, magnesium, and silicon (if you have a bit of chemistry background, it consists mainly of Al atoms with some Mg and Si atoms spread out in between the Al atoms to reduce its bending properties), which can take much more of a beating than regular aluminum without bending.
    Of course, plastic is much cheaper, and the part is fairly easy to replace, so you can't go wrong with either of them. It's just down to personal preference. The stock plastic is a little hard/brittle, but the rigidity is close to where I want it to be. I think RPM plastic is too soft. If it is under too much stress, it will bend and stay bent/rebound very little (which could take out other parts).
    Apr 2015
    Tinley Park, IL
    352
    I love the looks of aluminum of course.
    But, the rigid aluminum either transfers the shock farther into the suspension and drivetrain or bends in a crash.
    It’s just a preference.
    I use a mixture on my 4Pede and all plastic on the X except the motor mounts and servo horn.
    8,641
    Priceless. I bumped into the video again and noticed that I missed the driveshaft. Lol.
    Good work, RCWilly.
