Results 1 to 23 of 23
    Aug 2020
    57
    UDRís donít go to good in the snow
    Does a UDR with paddles go much better in the snow than regular tires?
    RC Qualifier Sp2deSummit's Avatar
    Feb 2019
    Yakima Washington
    433
    From what ive seen, anything goes well with paddles in snow. Not sure which ones will fit the UDR though
    Sent from my iPhone using Tapatalk for the first time
    I like free stuff!
    Nov 2018
    Livermore, CA
    875
    Quote Originally Posted by Sp2deSummit View Post
    At the expense of pointing out the obvious, uh, ahem
    https://traxxas.com/udr-accessories
    Feb 2019
    Yakima Washington
    433
    I did say it was my first time using tapatalk...
    Ikemort- Paddle tires are also good for sand. I have actually tried 3D printed "paddle tires" in the snow, those worked pretty well on my 1/16 summit. I'm not coming from no experience with paddles, though I realize now it may seem so from my initial post.
    Hope this helps man!
    I like free stuff!
    Feb 2020
    101
    I thought Traxxas had paddle tires for this truck
    Sent from my iPhone using Tapatalk Pro
    Dec 2003
    Dekalb, IL
    3,485
    Quote Originally Posted by dbestfromclovis View Post
    I believe that is what @TwoBelugas was hinting at:
    https://traxxas.com/products/parts/8475
    Aug 2020
    57
    I’m just wondering if they make enough of a difference to you at 60$ for them.
    RC Qualifier RCWilly's Avatar
    Feb 2019
    California Bay Area
    998
    They do make a lot of difference, but they are only limited to loose/soft surfaces, like snow, sand, and mud (maybe also good for hydroplaning on water). Other types of terrain may wear out the paddles very fast. Also, the UDR is a fairly heavy vehicle, so if you have a lighter vehicle for the job (like a slash 4x4), it would probably be more maneuverable.
    RC Qualifier ElectricPropils's Avatar
    Oct 2020
    Dallas TX
    386
    You forgot about how they make a cool noise when you drive!
    The present is theirs; the future, is mine.
    Dec 2003
    Dekalb, IL
    3,485
    Check out kevin talbot's channel. He's run them on his UDR in snow. Seems to get around pretty good.
    Oct 2018
    327
    I actually run my trucks more in the winter. Best thing I've found is snow chains. I had paddles and wasn't impressed. Paddles might be better for the light fluffy snow, but as for the ice, hard packed snow, and wet heavy snow, the snow chains are better. But I only run 1/10 scale size rigs, probably only hit 40mph max, not sure how a larger heavier possibly faster truck would be, or how well it would clear the snow chains. And its super cheap to make the chains, just buy like 30 feet of jack chain, and build them yourself. Does increase rotational mass, which could increase breakages, but didn't seem to increase my breakage rate over the years.
    Aug 2020
    57
    Where did you get the chains?
    Oct 2018
    327
    Homedepot, lowes, any hardware store. I'll take a picture of one of my wheels tomorrow, and let you know the chain size I use
    Oct 2018
    327
    Heres some pics of a set I'm currently making for a 5.25 inch tall tire. I used galvanized chain, since it'll be in the snow. The links do wear out over time, I probably replace about 6 to 10 links a winter.
    If you do build some yourself, hang them off a shelf or something like in the 2nd pic, makes it much easier to build without it getting twisted and tangled. I also would recommend getting 2 different types or colors of chains, like a thinner/smaller one for the 2 long sides, it'll make it easier to install on the tires. For reference, the sides are 11 inches long, the cross peices are 3.5 inches long. That fits snuggly on the 5.25 tall 2 inch wide tire. Your measurements will be different since your tires are larger. On my 2.8 trenchers they are 4 inches for the width, and about the same length. Takes some tinkering to get the first one done and fitting right, then the others are easy to make once you know the sizes. Once installed, they should fit nice and snug, shouldn't have any links flopping around if you shake the tire. But also shouldn't be crushing it either.
    Aug 2020
    57
    That looks awesome
    Do your trucks turn very good? I’ve heard that they don’t turn sharp once you put chains on.
    Feb 2020
    101
    Ah. I stand corrected
    Oct 2018
    327
    All mine turn the same. I only have open wheel trucks, so there's no clearance issues. It does get less traction on tar though. I generally stay off the pavement anyway, but with the chains on, it makes it slippery.
    Dec 2003
    Dekalb, IL
    3,485
    Quote Originally Posted by Steve g View Post
    What do you use to secure it to the tire on the back side? Ziptie, wire or did you find a good clasp to use?
    Feb 2019
    Yakima Washington
    433
    What size chain? Thinking of using this on my Sport.
    I like free stuff!
    Oct 2018
    327
    The back is the same as the front. Nothing extra. The links can be opened up and closed, so the same method of opening and closing a link to make the set of chains is the same method to attach to the tires.
    Oct 2018
    327
    Not sure on size, bought like 60 or maybe even 100 feet a couple few years ago. I'm actually out now, probably gonna pick more up within a week or 2, can let you know the size then.
    Mar 2017
    532
    It’s called jack chain and should be at any hardware store. I think it’s #16 I used, maybe?
    They should has some smaller stuff for hanging flower pots, bird feeders and such...
    Get brass if you can as it’s best for strength to weight ratio. Weight IS important!
    Aluminum is too soft and steel is too heavy(imo). Brass links are easily bent as well.
    Pretty sure I wanted at least 8 cross links to be effective. Hard to recall exactly. It’s been a while.
    I’ve moved to a few sets of paddles and also made spiked tire sets for use depending on conditions.
    Aug 2020
    57
    Do you think that they would work on a 6s udr?
