Results 1 to 10 of 10
    Jan 2020
    The Moon
    173
    Question Original length for steering rods?
    Hi Guys,
    I was wondering what the original length for the steering rods is on a sl4sh.I crashed it and snapped one, and when I bought new ones they were different lengths, so now it doesn't drive straight. I think I changed the length on both the rods, so I dont know the original length. Can someone tell me? I couldn't find it in my manual.
    Aug 2020
    37
    Hello
    I think 78 mm to 88 mm I broke 1 a arm and changed to all aluminum which are a little longer on the front so I needed to get longer rods
    I bought 93 to 103 and they fit great
    Jan 2020
    The Moon
    173
    Quote Originally Posted by Kanada killer View Post
    Hello
    Aren't they both the same length? I'm confused.
    14,274
    Easy thing to do is to put the part number into the search box of Traxxas's main site. If there are instructions for that part number it will show up on the results.
    Such as below:
    https://traxxas.com/sites/default/fi...B%20-%20EN.pdf
    Aug 2020
    37
    Quote Originally Posted by Invincibl View Post
    Well I am no expert
    Mine were shorter in the front then the back
    When I order the aluminum arm they came same front and back
    Now the aluminum front were 10 mm longer then the stock plastic arm
    So that is why all front rods were needed longer
    Jan 2020
    The Moon
    173
    Well I am no expert
    I just want to know the length of the rods from the steering bell crank to the steering blocks
    RC Qualifier NitroBugg's Avatar
    May 2018
    MS
    349
    I checked one of mine (hard to measure still on the truck), but it appears to be "about" 87mm-88mm from center holes.
    Traxxas part number is: 5539, but they only state the rod length as 58mm. Once the ends are added, the "overall" length is increased.
    Kinda confused about the "front and back" lengths mentioned above? Unless you have rear steering also, they're aren't but one set of steering links, (I call them toe links) and they are definitely on the front.
    Dec 2014
    Adirondacks
    2,470
    Have you clicked on the link Double G provided? It gives the stock length measurements.
    Aug 2020
    37
    Quote Originally Posted by NitroBugg View Post
    sorry if i caused any confusion
    my roller was bought used. it's front a arms are 10mm shorter then rear.
    i bought front and rear aluminum from integy and they are all the same length
    so front steering and camber were too short for the new arms i measured from eye to eye and found i needed 93-103 . ordered from integy and steering as well as toe in are perfect
    Aug 2020
    37
    i found the old stock a arms and here is a picture of them
    i dont know why they are different maybe someone changed these
    i bought my rolling chassis used from a local racer with mip axles for 120
    so it was my surprise when the integy arms arrived and the rods were short
    you can clearly see the front are shorter
