Results 1 to 10 of 10
Thread: Motor mount
    Nov 2015
    640
    Motor mount
    Hello. I've ordered a Traxxas Rustler 4x4 VXL
    This isn't my first rodeo with this sort of chassis. I've had 4 Slash 4x4's.
    On all of them, I've upgraded the motor mount with larger bearing.
    HOWEVER
    Is the Traxxas Slash 4x4 LCG motor mount the same as the Rustler 4x4 VXL one?
    Thanks
    Nov 2015
    640
    I've just noticed:
    The Slash 4x4 VXL has the part #TRA7460
    The Rustler 4x4 VXL has the part #TRA7460A
    Whats the difference? are they interchangeable?
    RC Champion Panther6834's Avatar
    Jan 2019
    SF Bay Area
    1,330
    Just different colors. You'll find the same part numbers, with different letters at the end, of many Traxxas parts, as a lot of parts can be purchased in black, gray, red, green, and blue.
    ~ More peace, love, laughter, & kindness would make the world a MUCH better place
    Nov 2015
    640
    So an aftermarket alloy LCG motor mount will fit both my Slash 4x4 and my Rustler 4x4?
    Nov 2018
    Livermore, CA
    878
    Quote Originally Posted by Kpowell911 View Post
    HOWEVER
    Thanks
    When you say larger bearing, do you mean thicker but same inner and outer diameter bearings, or drilling out the bearing area to accept bigger outer diameter bearing, or some other method?
    Nov 2015
    640
    The Hot Racing or Kingheadz Alloy motor mount has a larger bearing. This is what I put on all my Slash 4x4 based vehiclss
    May 2020
    5
    No, the kingz head motor mount for slash4x4 lcg will not work with the extended rustler 4x4 battery chassis. If you have the regular rustler 4x4 chassis then it will work. I just went through this when I converted to extended battery chassis.
    Nov 2015
    640
    Quote Originally Posted by vantaro28 View Post
    Thanks. My rustler isnt here yet so cant check
    May 2020
    5
    Slash 4x4 lcg kingz head motor mount originally on my rustler 4x4, but when I switched over that corner had to be modified to work with the extended battery chassis
    https://imageshack.com/i/pmMrhx0Wj
    Traxxas rustler 4x4 aluminum mount:
    https://imageshack.com/i/pmk5oALxj
    Nov 2015
    640
    Thank you for this, Im having a nightmare!
