Can I make any of the models fit my 2wd slash? Thanks!
Absolutely! GTR's for the Slash 4x4. I ran stock black springs front and rear with 40 weight Losi oil on all 4 corners. It's the best my truck ever drove. They are on my Stampede 4x4 now.
Sent from my LM-G710VM using Tapatalk
Yes, the GTR shocks will fit on the 2wd Slash, you will have to switch the ball in the lower rod end out of your old front shock to the new GTR front shock to get them to fit in the front control arm. Be sure NOT to buy GTR shocks for a Revo, Slayer or anything else other than a Slash as they are much shorter and will not work.
Sent from my VS996 using Tapatalk
These should fit on the front.
https://traxxas.com/products/parts/7461X
And these should fit the rear.
https://traxxas.com/products/parts/7462X
I went off of Traxxas's classification, the specs on the Slash indicate that the front uses Long shocks while the rear uses XXLong shocks.
The present is theirs; the future, is mine.
Thanks guys! Will these desert racer shocks work?
https://www.smalladdictionsrc.com/tr...-racer-blue-2/
Hey guys will these shocks from her desert race work do you know?
That's them! And as you can see they do not come with springs. Anything else you need is in the package and I believe there is a bottle of 40w oil also. GTR springs are much larger diameter than the Ultra or Big Bore shocks. I have not tried any non Traxxas springs on GTR shocks that I have used. Your spring choice will depend on your intended use, don't go with too stiff of a spring if you want to turn without flipping over.
Ok, i just read the rest of the listing. Those are UDR shocks, they would be much longer than the GTR XXL shocks. They wouldn't fit without modifications like taller shock towers. Even then i've never tried it myself. I did build a Slash with Stampede arms and extended shock mounts using Yeti shocks.
Okay man. Thanks so much. You can find them much more reasonable so I had high hopes lol
The ones on the UDR are waaay too long. You need the Long for the front and XXLong for the rear. If you look on eBay, there are a few sets that sell at fair prices, that are removed from new Slash 4x4 Ultimates (same GTR shocks)
There's a set of used ones (I would avoid it, unless your budget is very limited): https://www.ebay.com/itm/Traxxas-Rus...IAAOSwdpRfsypT
Here's two more links to new ones (removed from new Slash 4x4 Ultimates):
https://www.ebay.com/itm/SLASH-4x4-U...kAAOSwlAFb3H3~
https://www.ebay.com/itm/4-1-10-Trax...sAAOSwhU5fEkgP
Okay man. I'm not gonna buy used ones. Gonna get gtr x long in the front and xx long in the rear as ya'll suggested. Now to find springs. I can get the whole set new on amazing for about the cost if the used ones. Which is sketchy cause who knows what they were doing with them. I appreciate all of your help. Ya'll rock!
Jennys also has the blue ones for the Ultimate (3 sets available right now):
https://jennysrc.com/collections/sla...raxxas-68077-4
They are out of the plain ones for the Platinum.
Jenny is a great supplier has never let me down yet!![]()
The bottom two links I posted are new ones. The reason they are so cheap is that they are removed from new models (Slash 4x4 Ultimate). If you want to buy them separately, the front is only Long and the rear is XXLong. For the springs, TLR TENSCTE springs fit great. I run the red TLR springs in the front and orange TLR springs in the rear (on my Slash 4x4, they are fairly soft)
Last night on my Integy "Pro-Line Pro2 copy" chassis I used the GTR shocks off a Slayer/Revo on the front, changed from the super stiff Slayer/Revo springs to the double green stripe GTR springs. The only problem is the shoulder bolts are a loose fit in the shock caps but other than that I think they"ll work.
Sent from my moto g stylus using Tapatalk
Thanks everyone!
So they are only listed as used because they took them off a platinum? They've never been ran though? That's awesome man! Are they long and xx long? Thanks!
Awesome thank ya
In regards to the Revo (also for XO-1) GTR shocks, TRA5460, and those for the Slash, TRA7461, does anyone know what the extended & compressed lengths are for BOTH shocks? Traxxas doesn't publish this info, and finding it online is extremely difficult...at one point, I find the extended length of TRA7461, but I've never found the compressed length, nor could I find any lengths for TRA5460.
Also, to in regards to both shocks (TRA7461 & TRA5460), does anyone know which Losi springs fit? Not asking about spring rates, just which springs will physically fit. I understand (as pointed out by others) that the Front Tuning Set LOSB2959, should fit the Slash (TRA7461) GTRs. However, as for the Revo/XO-1 GTRs, I currently have no ideas.
~ More peace, love, laughter, & kindness would make the world a MUCH better place
X0-1 manual says:
The shocks are assembled at the factory with a center-to-center distance (between the rod end balls) of 87mm front and 83mm rear.
E-Revo 2.0 manual says:
The shocks are assembled at the factory with a center-to-center distance (between the rod end balls) of 87mm.
Neither manual gives the compressed lengths.
Have fun and have a blessed Thanksgiving!![]()
I just dug out my bag of shocks and measured about 68mm compressed with the blue bump stop.
Panther: What lengths are you hoping to acheive?
Approx 75mm...possibly slightly longer in the rear and/or slightly shorter in the front. These are for a Slash/Bandit-based No-Prep drag car. Options would be using the 'front' (ie. "Long") Slash GTRs at all four corners...or, using a combination of the 'front' Slash GTRs & Revo/XO-1 GTRs.
However, in further searching, I've discovered a "conflict" in the reported length of the Revo XO-1 GTRs. Some have said they're shorter than the 'front' Slash GTRs, while other people have said they're longer...so, now I'm confused. Are the Revo/XO-1 GTRs (TRA5460) longer, or shorter, than the 'front' Slash GTRs (TRA7461)???
In my street rig, I run Arrma Limitless 6s shocks front and rear. They are 79mm front and 85mm rear. The bodies are larger and you need to run them with standoffs:
https://forums.traxxas.com/showthrea...=1#post6551141
Unfortunately, I have a feeling that those might be too large in diameter. I was torn between the Traxxas Big Bore & GTR, and the Pro-Line ProSpec.
While the Big Bore are lighter, they also use clips for adjusting preload, which is why I eliminated them. Between the ProSpec & GTR, it's more of a personal matter. While the ProSpec is nice, smooth, and slightly thinner (I used to have them on my Rustler, until I switched to some Lodi shocks (and gave the ProSpecs to my step-dad, for his Slash), I've read, and heard, how smooth the GTR is. I also like the metal body-plastic cap combo, as opposed to the all-metal of the ProSpec, and all-plastic of the Big Bore & Ultra.
Even though the GTR is slightly larger in diameter (compared to the Big Bore & ProSpec), I'm 99% certain they'll fit (I have Delrin spacers, which I'd use as standoffs). Right now, it's just a matter of determining whether, or not, the Revo/XO-1 GTRs are usable (ie. the extended & compressed lengths), and whether they're longer, or shorter, than the 'front' Slash GTRs...and, if they are usable, what springs (Losi, if possible) will work with them.
I guess just get the GTRs and do the internal fuel tube mod to get it were you like.
Good luck!![]()
That's what is looking like...I was just trying to figure a way of not having to internally limit them, at least for the shocks in front...for the rear, it's ok.. While it does shorten the extended length (a 'good' thing), it also shortens the travel length ('bad' thing). The 75mm length I previously mentioned is the estimated length of the shocks when the vehicle is in its natural "resting" position.
With a drag car, the rear will never "lift", only "squat"...thus, the 'extended' length doesn't matter as much as the 'compressed' & 'travel' lengths. At the front end, while there's some "squat" when the nose returns to the ground, the more important aspect is when the nose "lifts"...thus, the 'extended' & 'travel' length matter more than the 'compressed' length.
I measured my Revo/Slayer shocks, 87mm extended, 70.5mm compressed, no bumper. These are center to center measurements.
