so I had a portal gear strip out when I took it apart the hex was split on that wheel so I decided to check the grease in all my portals and all 6 wheel hexes were split in half at the set screw. what would cause that? I have broke a few portal gear sets but never the hexes like this
Maybe defective hex metal? I find it hard to imagine all 6 being damaged without a defect...
Sent from my moto e5 cruise using Tapatalk
Ya can't polish fertilizer...
I can't imagine all the hexes breaking at once. Maybe you overtightened the set screws,
but the most likely reason is that the hexes were probably a bad batch.
Jumping: maneuver and pray it won't break.
Sounds like you had a REALLY bad batch on your rig. Recommend giving Traxxas a call. They are obviously defective, they will likely replace them.
