I have a stampede 4x4 vxl. I just finished replacing the front differential housing and bulkhead because they were cracked. Anyway, I noticed a looseness in the steering. Like, when I turn the front wheel back and forth with my hand, there is some looseness before it actually turns the servo. The back seems tight tho. Is that normal, or did I put it back together wrong?
Well of course the back is tight, there is no steering in the rear
Yeah, a fair amount of slack or "loosness" is normal. Every joint has a little slack and it all adds up. Of course, from your brief description, it's difficult to tell exactly how loose your steering is. This is a case where something like a short video would help a lot.
One easy thing to check is to make sure that your servo saver is not too loose.
The stock plastic C-Hubs will add some flex since they will bend a bit. The RPM C-Hubs are stronger (in the sense that they won't break as easily), but they bend even more. I usually recommend RPM upgrade parts over aluminum upgrade parts, but the C-Hubs might be one exception if you want to tighten up your steering a bit. I still prefer RPM if doing huge jumps or hardcore bashing.
Yes it look like it’s the servo saver that’s loose. Guess I’ll have to take it back apart again. I’m not quite sure what I need to do but hopefully I’ll figure it out.
