Well it is Xmas. Happy Xmass to all and God Bless America.
Here is an update. I decided to paint one of my clear bodies to match the Proline one. I had several cans of paint laying around so it was only the price of the body. I made some mistakes but next time it will come out better.
Let me know what you guys think of the 2nd Xmaxx 8s build. This body will be for the black and blue traxxas Xmaxx.
Sent from my SM-G965U1 using Tapatalk
I just finished dying the Proline rings to blue as the white looks ugly and swapped out 160 rusty bolts to stainless. That rust appeared after washing them one time.
Here are some before and after pics.
Enjoy
This will be my bashing truck as well but i don't want rust on it. I want to pressure wash it and get the dirt/mud off easily and make my cleanup with less headache. I used to clean and spray WD40 on the rims of my other cars to try to minimize the rust issues. I know people say the stainless screws are softer than the black OEM ones but it is not a problem as I have soo many stainless screws I can easily replace what is needed.
The screws were cheap on Amazon though so it was worth it. Heck I was rebuilding 2 trucks and now am building a 3rd since the 2nd one I bought gave me so many extra parts to start it. Cheers and thanks for replying.
I got some more parts in. Just found a savox SG 2290 servo and ordered the Kx one Juan told me about.
Here are some sleeves for the driveshaft cups I picked up to try out on 8s.
Also got a Proline bashing body in as well. Went to buy a Max5 for a crazy deal and also picked up a Spectrum DX6r remote. This thing is nuts with a ton of features. Will definitely use it on one of my Xmaxxes.
Happy New Year to all.
Th is the Proline body on the 3rd build I am working on with extra parts I have.
Happiness is;
Bashing 3 Xmaxx’s, one after another
fabricator
i did the same thing to mine a few weeks back. did a wheel a night while sitting down and watching tv. i'm eventually doing the whole truck in stainless bolts and bearings. i have the carriers done in stainless bearings now. waiting on the bearings to do the rest.
now i have to go through and find the sizes of all the bolts i will need.
Your Welcome and whatever questions you have please don't hesitate to ask. I have taken apart 2 used 6S and 1 8s and in the process of rebuilding all three of them. Yes you need the Rear Bulkhead Traxxas part # 7727x to accommodate the metal center diff that will take place of the plastic one. I just bought a couple extra chassis to have on hand but they are not needed for the 8S upgrade as yours will work fine. I figured extra so i can dye them black beforehand. To make a 6S to 8S it takes some money though. I have spent so much money just ordering on Ebay, Amain, Amazon, and my local hobby shops.
My plan so far:
1 xmaxx to use a HobbyWing Max 6 with stock motors 1275Kv or 1600Kv ?????
1 Xmaxx to use with a Hobbywing Max 6 and the Hobbywing 1650Kv with with WFO mount and HR 50T spur and 18T pinion
1 Xmaxx to use with a Hobbywing MAx5 and the 1100Kv combo with WFO mount and Mod 1.5 gears 30/25
Make sure to hit a 20 foot kicker flat out as soon as possible
Man I am addicted to the Xmaxx. I have like 4 Stampedes and 3 Slashes that I normally run. A friend let me drive his Xmaxx and I was hooked. I said ok let me buy one used since I would take it apart and upgrade it anyway. Sure enough started out and now have 3 I am in the process of building. They are awesome to work on and the upgrades can get crazy. So my vision is to build a normal pretty stock one and go from their to a crazy fast powerful build out.
Now just waiting for some more parts.
My buddy just built a sick xmaxx with the max5 it’s almost not drivable lol. I want to build the 6s I have into an 8s or get a new 8s truck.
Sent from my iPad using Tapatalk
I believe he is running 25/35 for gearing I’m not exactly sure but he has some serious money in it..
Here is what I have for a parts list for my 6s-8s build.. can anyone see if i am missing anything
Chevy my main man. This is what I gathered so far. I will look it over and make sure it is complete. THese are mostly my Hobbytown prices local to me.
Xmaxx 6s build to 8s
Rear Bulkhead chassis Tra7728x 20.00
Cush drive parts below and need 2 bearings size 6x13x5 BB
Traxxas X-Maxx Transmission Cush Drive Elastomer Damper---- TRA7794 3.00
Traxxas X-Maxx Transmission Cush Drive Input Shaft ---------TRA7786X 6.00
Traxxas Cush Drive Housing --------------------------------TRA7793X 3.00
Traxxas X-Maxx Transmission Input Gear (20T) ---------------TRA7785X 4.00
8s Driveshafts- You have to buy complete ones because the cups do not exchange from 6s to 8s. The 8s axles are thicker. I bought mine on ebay for 85.00 for all 4 shipped.
Ebay 85.00 from Jennys RC or luminadave
Diffs
7782- diff spider gears 20x2
Traxxas X-Maxx Heavy Duty Front Pinion Gear (11T) TRA7790 10.00
Traxxas X-Maxx Heavy Duty Rear Pinion Gear (11T) TRA7791 8.00
(2F&R)Traxxas X-Maxx Heavy Duty Ring Gear Gear (35T) TRA7792 10.00
(4 of these for F&R)Traxxas X-Maxx Drive Cup (8S Spec) TRA7754X 12.00
Center Diff Traxxas X-Maxx Torque-Biasing Center Drive TRA7796 65.00
Tires
Stock 8s 110 on ebay
Duratrax Six Pack X ( make sure you get X belted tires) mounted on rims 100-110 shipped for 4
Duratrax Hatchet X mounted on rims 100-110 shipped for 4
Pro line Badlands Beadlock wheels 200 for all 4 good but Heavywould be good for Max5/1100Kv build trucks IMO
Your awesome thanks. I don’t have a hobby shop near me so I am going to have to order everything online, closest hobby shop is about 4 hrs south of me
If I go with the max6 1100kv what gearing would be suggested for all around running? I’ve found some spur gears but having trouble finding pinions, do I need d bore gears for the max 6? I’m kinda lost when it comes to these new mod gears and diameter of shafts and stuff.
Here is the combo I plan to go with
https://www.ebay.com/itm/HWI38010802....m46890.l49292
I would not recommend the Max 6 with a 1100Kv motor. Everyone was telling me the same and now I understand by asking alot of guys that run this setup. I bought the combo and then found a Max5 for a good deal and grabbed it. The Max6 is geared more for a stock 8s vlx upgrade.
Yes, this is true. Max 6 is anemic for 1100 kv motor. It will quickly overheat and ultimately burn out from thermal overload. (Verified from personal experience)
That motor is hungry for amps. Better to pair it with a Max 5.
Sorry, maybe I’m not being clear. For replacement of the Traxxas 8s VXL ESC, the Max 6 is a great alternative if you’re keeping the stock VXL motor.
But for running anything more powerful (1000kv hobbywing motor in this case) no good.
Hobbywing 1650kv would work fine. Though, if you’re looking for major power upgrade you may find this motor lacking.
I would recommend 1100 KV or 800 KV w/Max 5.
Max5 won’t overpower. Just depends on batteries and motor. Best to match batteries, esc, and motor. For instance the 5898 can around 200 amp continuous, the Max5 is good for 200 amps continuous, my batteries are good for 205 amps. Geared 37/46. It’s a monster.
Wanting to run a Max 5/1100Kv combo will add more $$$ as you will need a motor mount(70-90), ESC mount (20-50)since it will not fit in the stock location, and strong pinion and spur gears (WFO mod 1.5 D bore come to mind and they are not cheap at 100.00. I see no one is explaining this to you as clear as this and it all depends how deep in the rabbit hole you want to go( your wallet).
On a different note since you are coming from a 6s to 8s upgrade which adds even more money I would go for the Max6/1650Kv upgrade to see how you like it. I would think that path would make you happy as the stock 1600Kv is no slouch on 8s. a lot of people don't recommend that since the motor is not recommended for 8s but a ton of people run it on Youtube without issues.
Look at RCKnockouts Max6/1650Kv setup on Youtube.
https://www.youtube.com/watch?v=i1zx...nel=RCKnockout
