Results 1 to 4 of 4
    May 2020
    62
    major loss of speed ( I may have accidentally changed something)
    I had an engine go bad on my 4Tec Nitro and recently replaced it. I also replaced the plastic gears (some teeth were broken) and the clutch shoes (spring was broken and shoes worn).
    I replaced the gears with the exact same parts.
    The last Traxxas App telemetry run I did was in June and the max speed was about 70 mph.
    In the same parking lot I made a telemetry run with the Traxxas App today and max speed was only about 50 mph
    I think I accidentally changed the shift point. Maybe something else?
    I don't know how to attach files to this post. So Here are graphs of the RPM and Speed from the June run
    https://www.dropbox.com/s/zr04xb0xht...20RPM.png?dl=0
    https://www.dropbox.com/s/y17jemibzf...Speed.png?dl=0
    Today's RPM and Speed
    https://www.dropbox.com/s/8lle1ed6p3...20RPM.png?dl=0
    https://www.dropbox.com/s/vf0sy4m7lm...Speed.png?dl=0
    Any help in getting back to better speed is greatly appreciated
    Thanks
    Good afternoon, please tell me if you were able to solve this problem? I understand correctly, the loss of speed occurred after replacing some elements?
    May 2020
    62
    Quote Originally Posted by PhillipDine View Post
    That is correct. I had to replace the engine and a few other parts and it doesn't seem to have the speed it had before.
    Unfortunately it got to cold to continue testing. I will work on this when the weather warms up
    Okay, good luck to you!
