My wife got me a TRX-6 for my birthday. My first r/c and I am HOOKED! Already ordered a bunch of upgrades for it. I’ll update this thread as I go along. Got a lot to learn and read up.
WELCOME TO THE FORUMS!!!!
...and, welcome to the TRX6 club! Its a great rig.
Congrats on your great wife and welcome to the Traxxas forums!
Have fun!![]()
Thanks for the warm welcome, all! Got these installed:
Protek RC 370TBL “Black Label” waterproof steering servo
Castle Creations BEC 2.0 waterproof
Reefs V2 servo horn
Magnetic post mounts (EBay)
The upgraded 7.2v steering servo setup is much better! Definitely more powerful than the factory 6v from Traxxas. The magnetic mount was very simple to install. I was more excited about the magnetic posts than the servo upgrade. lol
Welcome!!!
Thanks for the kind words! Hope everyone had a great holiday weekend. Here’s what’s next:
Samix steering knuckles, c-hub, portal housing, & brake rotor set (Front)
Samix brass shock spring cups
Hot Racing steel offset steering tie rod
AJRC skid plates
Big difference after adding the brass weights to the front axle housing! The brake rotor set compliments the scale look really well. The factory steering tie rod hits the differential cover at full lock. The offset steering tie rod fixed that issue. Problem is now I have a bigger steering angle and is hitting something else..![]()
Have you tried to reset your steering endpoints on your Tx?
Have fun!![]()
get a stainless steel front bumper skid plate it has held my bumper and frame together through so really hard hits
Up next:
RC4WD Warn 9.5ct winch
RC4WD Warn wireless controller
RC4WD front bumper
RC4WD Warn fairlead
RC4WD Warn shackles
Was advised by a local r/c shop not to wire the winch controller directly to the battery.. so I disassembled and scavenged a 9v battery connector from my old smoke detector. Next would be to waterproof the controller and figure out how to mount the bumper to the TRX-6. This is going to be a challenge. To be continued...
Installed a truck bed conversion kit (EBay)
Very surprised as to how this turned out. I’m quite please with how well the fitment was. It fits and feels like this bed came from the Traxxas factory. Highly recommended to anyone with a TRX-6 to add this mod.
That bed looks spot on. Can't beat a more detailed part.
Figuring out how to mount that bumper will be well worth it!
'If it's free, I'm buying two!'
Is that the RC4WD bumper for TF2? with rounded posts?.You might need this adapter
https://store.rc4wd.com/RC4WD-Alumin...-4_p_5832.html
Aftermarket stuff for the TRX6 is so addictive, I already sink few grand in scale parts already. Be warned![]()
I purchased the RC4WD TRX4 front bumper conversion. It's supposed to have a tighter fit to the mounting posts on the RC4WD bumper. Since the bumper was designed for another chassis, it sits far too low or far too high to my TRX-6. My friend with some godly machining skills fabricated an adapter piece to make it all fit like puzzle piecesCheck back later today for the updates!
Continuing my winch/bumper mod...
I singled out a 9v battery holder from a row that holds four I had bought from Amazon. Also bought a cheap "scale storage box" to waterproof/dustproof the wireless winch controller with some silicone gasket maker. Here's how they look like:
I carefully cut away the front bumper. Making the cut at the front of the fender flares on both sides to match was not easy, but I think I did a pretty good job
Soldered on a waterproof on/off switch externally for the battery. This way, I don't have to remove the body to plug/unplug the battery every time. The switch will be hidden on the undercarriage right behind the front bumper.
Mounted up the roof lights. Also added some LEDs into them.
Very cool looking set of lights!
Thanks, JonnyUK! They're a bit dim.. I reconnected it to 6v to brighten them up. Also got a liquid chrome pen to plate the inside of the light bezel. Pictures to follow soon on that.
Back to the winch and front bumper:
The mounting posts on the RC4WD front bumper made it sit too high or too low to the body. My friend with fabrication skills made me an adapter out of a solid aluminum block:
Fitment is PERFECT and ROCK SOLID! Used the winch to pull my office chair. No flex on the winch or bumper. Form and function like it was made at the Traxxas factory!![]()
The roof lights were too dim when I wired it to the Traxxas LED power supply. I re-connected it to a Y-harness to the receiver box for a 6v power supply and now it is where the brightness should be. I also used a liquid chrome marker to plate the four individual light bezels to enhance the output. Success!
Before:
After:
Looking really nice and really good work on the bed!
I made one out of styrene way back when, there weren't any aftermarket options. it did turn out kind of ehhhhh in some places.
But really nice build so far!
Jumping: maneuver and pray it won't break.
Got0wned, you rig looks amazing.
looking sharp!
Titanium94010, Juanmacine, ben1272: Thanks! I appreciate the kind words. I already have more parts on order. Overdrive gear and pinion coming in this week among a few other parts!
Played in the snow today by Lake Arrowhead with the Deep Terrain Traxx installed. I was surprised how well it crawled through thick snow.
That's Awesome!! Debating on a trx6 and maxx. Love the upgrades if i ever get one i gonna copy you. When you are all done with it can you post all the parts you used. Thanks
Allyeajackvk2: if you plan on using the trx6 in snow, mud, or loose sand, the traxx in the front with deep terrain treads works REALLY well. And sure, I’ll update my list of mods of everything I’ve done soon after my next set of parts come in the mail.
Juanmacine: I should’ve build another snowman riding the bed of my trx-6![]()
Awesome tracks!
Do you plan on lifting the rear?
Titanium94010: I don’t plan on using the traxx too often, so I won’t be lifting it for that purpose. I have been toying with the idea of getting 100mm shocks all around to increase articulation. Not sure if that’s a good idea or a bad idea.
100mm Shocks will increase articulation by quite a bit, but if you keep it at stock ride height (with droop), you'll lose a little bit of suspension travel. Or you can run them with a lift and it works just as well, just you're car's going to be a little higher up.
Good shocks can be expensive though, especially if you need 6 of them.
I looked into get aluminum adjustable front shock towers that will give me added height for the top mount. I’ll have to trim the inner fenders. And for the rear, I could reposition the shock to the most forward mounting point. I think that will allow me to run 100mm shocks without raising the center of gravity and still give me more shock travel. But you’re right... buying 6 new quality shocks could get expensive.. but I’m already in too deep.. LOL![]()
