Results 1 to 40 of 40
    Aug 2014
    Blytheville AR
    42
    Wheels turn opposite direction
    This one I think I know, but being the best bestest rc machanic in the world.. Im gonna quizz you. guys... Lol truck powers up. Steering works.. But when I give it throttle front tires and rear tires spin in opposite direction...
    P.s. I'm almost finished with this learning experience.
    Sent from my LM-V350 using Tapatalk
    Nov 2019
    192
    As in both front wheels try to drive forward and both rear wheels try to drive backwards?
    Aug 2014
    Blytheville AR
    42
    Yes it is front is going one dirertion. The rear wheels are going a different direction And reverse is also the sane
    Jan 2021
    46
    Did you have both diffs out at the same time? Searching for a hint. Lol
    Sent from my SM-G955U using Tapatalk
    Nov 2019
    192
    Quote Originally Posted by Erevs View Post
    I think you got it... One of them went back in flipped left/right. So the gear mesh changed sides and as a result so did the output direction.
    Aug 2014
    Blytheville AR
    42
    No never had the rear out only built new tranny from parts. And same with front diff.
    Aug 2014
    Blytheville AR
    42
    Ok thank you.. Ive been working on this erevo for 2 months. My fingers are so sore..
    Jan 2021
    46
    Geez, I'm trying to think what parts you'd have to flip to get that combo. Still scratching my head. I know you have the answer but let me think for a minute
    Aug 2014
    Blytheville AR
    42
    No it wasnt a quizz lol... For real problem.
    Aug 2014
    Blytheville AR
    42
    I first tries it on ice and I thought
    The traction on this sucks
    Jan 2021
    46
    Ahhhh, okay. One sec because I literally just tore mine down to only the chassis and rebuilt everything.
    Nov 2019
    192
    To be clear, I'm guessing with my solution. But it would explain things. It would also be kind of a bad design though if the diffs could be flipped left/right.
    Jan 2021
    46
    Dying, lol!!!
    Aug 2014
    Blytheville AR
    42
    I guess I could have pit trans mission in backwords.
    Jan 2021
    46
    When you hit forward throttle do the front wheels drive forward?
    Nov 2019
    192
    Quote Originally Posted by rlzangerl View Post
    I don't think flipping the center diff would do this. Only flipping a front or rear diff.
    Aug 2014
    Blytheville AR
    42
    I will check. All I know is they are definitely going in reversedirection from rear
    Jan 2021
    46
    I'm thinking if the front wheels are pulling the way they're supposed to then take your rear diff cup and flip it over. Using the paint can as a visual of just turning over and the left being where the right was.
    Nov 2019
    192
    Unless it's the front one that is reversed, and the motor direction is also reversed (needs wires switched)
    Aug 2014
    Blytheville AR
    42
    What order are motor wires?
    Jan 2021
    46
    Quote Originally Posted by omen View Post
    Too much brain power for me Omen. Haaa
    Jan 2021
    46
    Finger and thumb go to same wire
    Nov 2019
    192
    I wouldn't worry about the wiring order yet. Sort the diffs first. Having the wrong wire sequence is an easy fix once everything else is sorted.
    Dec 2014
    Adirondacks
    2,838
    Is this an Erevo 2.0? If it is I don't see how the Front/Rear diffs could be flipped the wrong way. The bulkheads only allow the diff gears to be installed one direction.
    Did you take apart the center diff in the transmission?
    Aug 2014
    Blytheville AR
    42
    The sequence of rhe wirss could be wrongbecause they Did. Not have opositeends the same color. So I guesed
    Aug 2014
    Blytheville AR
    42
    This is the erevo 1. With all of the 2.0 stuff I. It.
    Aug 2014
    Blytheville AR
    42
    Yes I built center diff from all new parts. Drive shafts all. Has given me help.
    Aug 2014
    Blytheville AR
    42
    If I unhook both drive shafts. When I spin the gear they should turn the sanme direction .
    Dec 2014
    Adirondacks
    2,838
    Being a V1 erevo, it's possible to have installed one of the differentials installed flipped over. Either your front or rear differential is installed wrong. Here is a picture showing how they should be installed.
    Dec 2014
    Adirondacks
    2,838
    I'm not sure there is that much from the Erevo 2.0 installed on your Erevo V1. It looks like the transmission is the only thing installed. The Erevo 2.0 has different differentials and bulkheads. Also uses different axles. It's the entire driveline that makes them different.
    Aug 2014
    Blytheville AR
    42
    Oh. Im Very sorry if I misled any one. I sure didnt mean too. I sent a pic to traxxas and they replied erevo brushless" . I guess I'm on the wrong forum as well. I appologize to everyone!
    Sincerely R Zangerl.
    Dec 2014
    Adirondacks
    2,838
    No need to apologize. Your in the right place. There is two different versions, that's all.
    It's easier to help when we know what truck we're talking about.
    Traxxas themselves make this model confusing. The V1 was called Erevo brushless and they call the new one Erevo VXL brushless. Pretty much the same name.
  33. #33
    Jan 2021
    46
    Ur fine man. Regardless it's the same issue. I think what I would do to troubleshoot is take all the skid plates off the bottom and visually look for where the shafts are spinning opposite direction. At that point is where you'll find the issue/something flipped.
    For it to be correct, at the the transmission it should drop down and have the front center and rear center driveshaft spinning the same direction. Wordy but hopefully that makes sense
  34. #34
    Aug 2014
    Blytheville AR
    42
    Ok. Thank you. Thats tje while problem. I bought about 8. Trucks 60ish tires. 25 radios. 3 near rnr
    Trucks. For $60. I didnt.know what I had either.
  35. #35
    Oct 2018
    Texas, by God!
    110
    Take out the diff. Look at the housing for the diff. You'll see a little triangle. Make sure the triangle is pointed up when you reassemble it . That should fix your problem.
    I find your lack of teepee disturbing.
  36. #36
    Aug 2014
    Blytheville AR
    42
    Thank you very much!
  37. #37
    Jan 2021
    46
    You gotta let me know when u get this fixed and what you found.
    Feel free to private message me on here if you're still troubleshooting and don't want to post.
  38. #38
    Aug 2014
    Blytheville AR
    42
    Thanks. I will. We getting hit with 10 inches Of snow in Arkansas.
    Which we ate not used too. So I will let you know..thnx.
  39. #39
    Traxxas Employee Nitro Chicken's Avatar
    Jan 2001
    Chicken coop
    6,568
    Grizzly03 is exactly correct. One of your diffs is upside down
    "Fortunately son, I says fortunately I keep my feathers numbered for just such an emergency!"
    Foghorn Leghorn
  40. #40
    Jan 2021
    22
    The er v1 diffs can 100% be put in backwards.
    Guilty of it myself. It went in easier backwards than the right way shockingly lol
