Thread: Run time?
    RC Qualifier ThatTraxxas's Avatar
    Jan 2021
    Ontario Canada
    329
    Run time?
    Hello,
    Does anyone know the run time when running the xmaxx on two 6700mAh batteries. Or the run time on two 5000mAh batteries?
    Thanks in advance
    1/16 E-Revo VXL, Bandit XL-5 Just Gonna Send It!!
    Nov 2020
    242
    I think you're going to get a lot of "how long is a piece of string" type answers, because much like a rear car, the length of time the "fuel" lasts depends on how you drive it. If you go flat out the whole time then you might be looking at 15 - 20 minutes, but in reality you don't tend to pin the throttle wide open the whole time without stopping, so you might get 30 - 40 minutes.
    Sent from my LYA-L09 using Tapatalk
    RC Champion Acidic01's Avatar
    Jul 2018
    beaverton oregon
    1,971
    Quote Originally Posted by RJUK View Post
    +1.
    Cold weather also reduces run time as well. Gearing plays a factor as well.
    *No need for the innuendos.*
    Nov 2020
    242
    I guess you could lessen the issue of cold by keeping your batteries indoors and charging them just before you go out, then keeping them in a coat pocket or something whilst you're out, to use your body heat to keep them warm. Once in the car using them should keep them warm.
    Jan 2021
    Ontario Canada
    329
    Yes, if I were to be let’s say bashing at a skate park kinda thing how long? I’m not really a “speed run” kinda guy so prob stock gearing.
    Nov 2020
    Canada
    168
    50 minutes with the 6700 normal driving
    Apr 2015
    Tinley Park, IL
    425
    I have some 3S 10,000 mah SMC’s that I don’t think I ever hit LVC with them. Well over 45 minutes of bashing about in grass.
    I have 4700 mah 4S batts and get over 30 minutes before they shut down.
    *See my edit above*
    Jun 2020
    Texas
    427
    I have a pretty much stock X-Maxx, with the dual 6700 Traxxas batteries. I get anywhere from 50min to 90min depending on how hard I am bashing. I noticed the snow we have had here recently in Texas not only lowered the run time but also the performance (punch) I was getting, so temps for sure play in too.
    I could see less run time if I was just going all out continuously.
    Jan 2021
    Ontario Canada
    329
    Ok thank you all!
