Results 1 to 30 of 30
    Feb 2021
    27
    Open differential question
    Wondering how many have changed the differential to the open mod, I've only seen some on YouTube but they don't test it very much. Wondering if any one would have feedback pro's/con's.
    Thank you
    RC Champion RCWilly's Avatar
    Feb 2019
    California Bay Area
    1,327
    Traxxas has the rear diff for the UDR, so no mod is needed to make the rear open (I'm pretty sure the videos were made before the full rear differential was released):
    https://traxxas.com/products/parts/8576
    Feb 2021
    27
    RCWilly,
    I new to this so bear with me, will this diff rear that you linked reduce the roll overs, I was trying to read up on it to help reduce rollovers.
    Thanks for your time
    Aug 2020
    134
    Rc Wiley, Mod means modification
    I have not trued the diff mod but Iíll bet it will make it handle great.
    Feb 2021
    27
    Sorry guys for the questions, will the rear diff that RCWilly linked too act as an open diff like the videos?
    This is what I'm trying to achieve
    https://www.youtube.com/watch?v=3yNuJnXarWY
    Feb 2019
    California Bay Area
    1,327
    Quote Originally Posted by firemedicUSAR View Post
    RCWilly,
    I haven't installed it on mines, but the rear differential will definitely help reduce rollovers when turning.
    Feb 2021
    27
    RCWilly,
    Thank you for your help, have you added different sway bars or adjusted the shock oil weight?
    Aug 2020
    134
    I have 70 weight shock oil in the rear and 40 in the front and no sway bars and mine handles fine. And it is a cheap mod
    Feb 2019
    California Bay Area
    1,327
    RCWilly,
    I did not adjust the sway bars or shock oil, since I liked how it handles stock, but thicker shock oil and stiffer springs will help make it more stable at higher speeds (too thick could be detrimental as well, so find a happy medium for your setup).
    Apr 2018
    102
    The open diff helps the truck from rolling over as much. More so if you're on pavement or hard packed ground. I think it's worth it.
    I recently swapped the front sway bar as I was running in sand more often, and I will say that made it much more sketchy on pavement. In the soft it helps to rotate the truck, but on pavement it's much more difficult to keep it straight.
    I'd pass on the sway bar and go for the diff.
    Jun 2018
    127
    I switched to the open diff...and its so easy...and its awesome....drifts....powerslides.....drives awesome...you won't regret doing it....easy to do.
    Feb 2021
    27
    Unfortunately the area I live I mostly run on street, yards and football fields. I'm gonna switch to the open diff, do you guys have any recommendations on grease?
    Thank you to all that replied, I truly appreciate it!
    Feb 2019
    California Bay Area
    1,327
    I think the differential comes filled with silicone fluid, not completely sure about the viscocity. For the other gears, I use marine grease:
    https://www.amainhobbies.com/maxima-...-80916/p548109
    Aug 2020
    134
    I use marine grease for everything including differentials
    Mar 2016
    1,498
    1M in the rear diff has been excellent
    fabricator
    Feb 2021
    27
    With the open diff from traxxas or the mod from the video in previous comment above, do you loose the caliper for the brake, the guy mentioned it in the video but wasn't sure if it would be the same for the part from traxxas.
    Thanks for all your help
    Feb 2019
    California Bay Area
    1,327
    No, you actually still get to keep it. The rear differential drops right in and fits without drawbacks. I think the video you were referring to was made before Traxxas came out with the rear diff. Just to clarify, you only need the rear differential and some grease.
    Feb 2021
    27
    RCWilly,
    Thank you that helps! Just wondering I was looking at the traxxas web site and they have aluminum trailing arms, are they any good? Is any of their aluminum stuff good? (Toe links, shock caps ect)
    Thanks again for all your help
    Mar 2015
    343
    Traxxas' aluminum parts are prime time.
    There definitely are RC companies whose aluminum is to be mostly avoided, but Traxxas isn't one of them. GPM and Integy have a reputation for being junk, Chinese cast aluminum. Sometimes their stuff is decent but usually their bad reputation is proven true.
    Buy Traxxas with confidence.
    Feb 2021
    27
    Fallen,
    I was just reading up on those two, I was also told RPM's plastic doesn't hold up. Do you have any experience with Vitavon?
    Mar 2015
    343
    I don't, but several forum members have great things to say about Vitavon. Seems worth the cost.
    RPM's parts are solid, and they do hold up to severe abuse.. The RPM front suspension parts for the UDR have been reported to have clearance issues however, making them a swing and a miss.
    I have RPM'S trailing arms on my UDR and I've been very happy with them.
    Aug 2020
    134
    I have rpm trailing arms on mine an d they are doing great.
    I have the vitavon rear axle housing and beadlocks and they are doing great. I had the gpm axle housing but it had tons of problems. Vitavon is well worth the cost and I recommend them. As far as traxxas aluminum parts, I think they are nice but way too expensive. Their aluminum trailing arms are 130$ when I could go buy the rpm ones for 15.
    Feb 2021
    27
    Ikemort, Fallen
    That's good to know on the RPM, per your guys recommendation I ordered a spare pair of RPM trailing arms. Currently I'm driving on the street due to the amount of snow we have, I'm waiting on the rear diff to come back in stock.
    On a side note I was watching a video on the Losi SBR 2.0 and it rolled just as easy as the UDR. I don't see anyone talking about that issue.
    Aug 2020
    134
    I would also recommend the rpm front bumper and skidplate because the stock one broke within a few runs.
    I have seen the sbr roll a lot too but these trucks are made to be realistic so it doesn’t surprise me that they can roll over easy. You just have to learn how to drive it and not roll over.
    Feb 2021
    27
    Ikemort,
    When you say broke within a few runs, where you driving it hard?
    Aug 2020
    134
    Well I endoed it pretty hard but most of the damage was the skid plate from hitting the ground when jumping. I’ve also endoed it quite a bit with the RPM bumper and it takes it great.
    Feb 2021
    27
    Just out of curiosity I was reading the rear diff install and they use Traxxas grease, how does that stand up to marine grease, Lucus, 1M or other brands.
    https://traxxas.com/news/udr/rear-di...l-installation
    Feb 2019
    California Bay Area
    1,327
    I've only ever used Marine grease and the Traxxas grease, and I can't really tell the difference other than the color.
    RC Qualifier Nickerz's Avatar
    Jan 2016
    250
    This Can Save Ya Some Money Doing The Same Thing...
    Feb 2021
    27
    Thank you I will look into it!
