I was just wondering if there is any way to make the wheels sit out wider. sorry for not knowing how to describe this but the shaft that the wheel goes on that you put the nut on, if that was longer and you put some washers on there, would that work or no
"The fun begins when the trail ends"
I believe you can get hub extensions. Have a Google for those.
Sent from my LYA-L09 using Tapatalk
Look for wheel hex extenders, specifically for the TRX-4. They come in different sizes depending on how much you want to extend your wheel track.
If you are looking for more than 15mm, I would suggest to get a kit that incudes the extended axle as well.
If you are planning on getting wider hexes, the front tires may rub the body when turning, so you may need to adjust and trim the body.
I use the treal +5 on my trx6 it gets wheel outside the body so it right itself most roll overs
I was planning on getting a jeep hardbody which is the main reason I am looking for this
I love the look of wider wheels.
