    Jul 2019
    Washington
    96
    Help with new motor
    I just ordered the AXE 550 FOC combo.
    Am I going to need a BEC?
    I'm also looking for aluminum axles, or better.
    I run:
    2.2s InterCo Super Swamper XL
    Chanquish Beadlocks
    Long arm lift
    Samix brass (all over)
    machined gears
    ProTek 370 TBL servo
    3 EcoPower 640 micro servo
    MIP +4mm wide track kit
    MIP Driveline
    Samix +8mm Hex adapter
    FlySky GT-5
    N. Idaho... Da Sticks!
    8,248
    The ESC has a 6A BEC, which should be more than plenty for just about anything you throw at it. It also has two voltage settings, 6 and 7.2, the manual I found says your RX should be able to handle the higher voltage with no problems, but I would verify that before putting power to it.
    RC Champion RCWilly's Avatar
    Feb 2019
    California Bay Area
    1,326
    I agree with Greatscott that the internal BEC of the Hobbywing is pretty strong. However, it's probably better to stay at 6V, since the Eco Power shift servos can take 6V tops.
    Feb 2020
    2,041
    Agree with Greatscott and RCWilly, the internal BEC of AXE systems are perfect and powerfull.
