What will happen if I put the lower geared Stampede brushed diff in the front of my Slash vxl? Will it work at all? Will I get more power to the rear wheels?
Not necessarily more power, but the rear tires will spin faster than the front. What are you looking to achieve?
Not sure what I'm looking for. It was just a thought that come by. More fun to drift and slide perhaps?
With video...lol
Seriously, though, that is, essentially, how most crawlers are, albeit reversed (ie. the OD is in the front). At the same time, I do see a way it would work. If you look at the Arrma Felony, the front & rear diff are geared differently, with the rear having a lower ratio. At the same time, the rear also uses larger diameter wheels & tires, which 'condensates' for the different gear ratios. In the end, the distance the rear tires travels on one rotation equals the distance traveled by the front tires on one rotation...so, no damage being caused. Obviously, the "trick" is being able to correctly determine the proper gear ratios for front & rear diffs...which, obviously, required knowing (in advance) the diameters of the front & rear tires.
So, it IS possible...but ONLY if different diameter tires are also used. The calculations will be difficult, but, of some correctly, it could produce a very "interesting" vehicle.
~ More peace, love, and kindness would make the world a much better place
