Results 1 to 13 of 13
    Jul 2006
    Singapore
    34
    Xmaxx pinion always loose, true??
    Hi all, bought the 10th scale maxx 2 weeks ago and enjoying every run.
    Decided to go for bigger brother Xmaxx. However saw couple of videos and reviews, some are having serious issues to pinion gear getting loose each and every run?! Even tried Blue and Red threadlock also having the same loosen pinion.
    Please advice if anyone face the same issues and is there any permanent solution for it? I don't wish the pinion loosen every runs and spoil the fun of the huge maxx!
    RC Racer Bigtim29's Avatar
    Apr 2019
    199
    Iíll be honest, I use blue thread locker still. I just tighten that grub screw down as hard as I possibly can.
    Mar 2021
    64
    The motor gets hot, then softens the thread lock, then pinion slips. Keep your motor temps in check.
    RC Champion Acidic01's Avatar
    Jul 2018
    beaverton oregon
    1,971
    The fix is mark here the grub screw sits then the drill. Small divot into the motor shaft.
    Only a handful have had this issue. I have not.
    It may be where the stock motor shaft were slightly tapered due to manufacturing issues.
    Feb 2020
    Morristown, NJ USA
    310
    Of course thereís the ultimate fix......
    https://wforccustoms.com/products/ultimate-combo-kit
    Apr 2015
    Tinley Park, IL
    425
    After about 2 years I started having this issue.
    Marked the position of the grub screw, clamped the shaft with some vice grips, and used a dremel cut off wheel to make a series of grooves in that area.
    Hasnít budged since.
    Dec 2020
    Bedford, NH
    53
    FWIW, I was paranoid about checking everything on my X-Maxx when I received it, as I had been scared to death with all the "disaster first-time-out" videos about the X-Maxx online. I checked my pinion (along with everything else) and found it tight.
    It has not loosened for me at all, even though I've only been able to drive it a handful of times, so far.
    smp
    Stephen
    Traxxas XMaxx 8S (orange)
    RC Qualifier ThatTraxxas's Avatar
    Jan 2021
    Ontario Canada
    329
    I would get the arrma pinion from an outcast 8s.
    1/16 E-Revo VXL, Bandit XL-5 Just Gonna Send It!!
    Jul 2006
    Singapore
    34
    Quote Originally Posted by Dmarzke View Post
    Hasn’t budged since.
    Appreicated if you can provide some pics for sharing sir.
    Jul 2006
    Singapore
    34
    Quote Originally Posted by ThatTraxxas View Post
    I don't think the Armma pinion can fit into the stock motor shaft all the way in without any modification to the stock motor shaft.
    Apr 2015
    Tinley Park, IL
    425
    Quote Originally Posted by evo165 View Post
    Actually I got the idea on here some place.
    I will see if you can see it in the car tomorrow.
    Eastern Shore, Maryland
    4,836
    If your truck's motor is running hot enough to loosen Red Loctite you might need to change your gearing, or get a stronger motor. You can make a temporary band-aid by carving out a notch in your motor's shaft, but down the road (I suspect) your motor is going to poop out on you. It takes a lot of heat to loosen Red Loctite.
    Dec 2001
    the 5th dimension
    1,290
    Yes!
    Cleaned mine with isopropyl alcohol, blue loctite when I geared up a bit with the 50t spur and larger pinion gears on 8s, tighten it well with a real wrench, but not too tight.
