Results 1 to 34 of 34
    RC Racer allyeajackvk2's Avatar
    Nov 2020
    Mars
    191
    Lightbulb My 3D Printed Trailer Building Thread
    First off Shoutout to Goodson Hobbies on Thingiverse I will link him below. So far I have printed the axle, leaf spring, and the frame. Pictures down below.
    Here is Goodson's Trailer Collection
    https://www.thingiverse.com/goodsons...scaler-trailer
    When You Feel Down Send It To The MOON!!
    RC Qualifier ThatTraxxas's Avatar
    Jan 2021
    Ontario Canada
    326
    Very nice! Are you going to make it a flatbed, box, or something else?
    1/16 E-Revo VXL, Bandit XL-5 Just Gonna Send It!!
    Nov 2020
    Mars
    191
    Jan 2021
    Ontario Canada
    326
    Nice, you will need some kind of mesh. Are you going to paint it?
    Nov 2020
    Mars
    191
    yes and the model has mesh to print
    Jan 2021
    Ontario Canada
    326
    Oh. Looking forward to seeing it done!
    Nov 2020
    Mars
    191
    Me too!!!!
    Nov 2020
    Mars
    191
    Here's the printer I am using for this project. And here it is printing the fenders
    Jan 2021
    Ontario Canada
    326
    Nice!!! Can’t wait! LOL
    Nov 2020
    Mars
    191
    The last of the parts for the main part of the Trailer is done!! The fenders did tear a little bit so I used some Loctite Ultra Grab Caulking. All parts will be painted. All I need is the screws then I can print the utility trailer add on.
    Jan 2021
    Ontario Canada
    326
    Sweet!! That’s gonna look cool!
    Nov 2020
    Mars
    191
    You bet it is!!!
    Nov 2020
    Mars
    191
    So the fenders ripped some more so i smeared hot glue on the back to strengthen it
    Jan 2021
    Ontario Canada
    326
    Ok. You might wanna file the hot glue down a little so it’s not so bumpy and noticeable.
    Nov 2020
    Mars
    191
    I did it on the back only so it would look kinda like dirt build up
    Jan 2021
    Ontario Canada
    326
    Oh. It should be fine then.
    Nov 2020
    Mars
    191
    Yep.......
    Sep 2013
    360
    Quote Originally Posted by allyeajackvk2 View Post
    Don't know what color you plan on painting it but if the thickness/thinness of the fenders keep giving you an issue there is a low cost spray can type bedliner material at the home improvement stores that a coat or two of that would probably help stiffen up the fenders..that stuff is pretty rugged once dry.
    Sent from my moto z4 using Tapatalk
    Nov 2020
    Mars
    191
    Quote Originally Posted by radio uncontrol View Post
    But doesn't that stuff melt plastic.
    Sep 2013
    360
    Probably, if you went to a line-x shop or the like...
    The stuff they have in the rattle cans is not nearly as volatile..
    Scuff up the item with fine grit to help promote adhesion or 3M even makes an adhesion promoter #94 and do light coats..heavy coats won't get you your desired result.
    Sep 2013
    360
    The 3M will be enough for the surface area you are covering..anything more I would recommend this...I say it's a must or the top coat will eventually flake off without it
    Nov 2020
    Mars
    191
    Hmm I just don't wanna melt them. My dad said it would so I'm gonna research it.
    Sep 2013
    360
    All good..you can test that theory with a piece of your 3D scrap..
    Or thin gauge sheet metal and make your own ��
    Nov 2020
    Mars
    191
    Sep 2013
    360
    Yea, all the spray can stuff is the same..the ones I posted was just an example to give you an idea of what to look for..
    You don't want the roll on or brushed bedliner products..just the spray can type like you just posted..
    Will your printer not make the fenders any thicker?
    Nov 2020
    Mars
    191
    Well i did not design it i would have to do more infill but just wanna make these work for now.
    Sep 2013
    360
    Ah, ok
    Nov 2020
    Mars
    191
    Thanks for the help. I will probably go to home depot for the screws and paint!! I will keep you guys posted
    Nov 2020
    Mars
    191
    Sorry for no updates. I forgot to print the shackles for the leaf springs. I will try to print those later today. Got the leaf springs together for the most part. just need 2 nuts and 1 screw to finish them! I will post the pic of the partly finished leaf springs in a bit.
    Nov 2020
    Mars
    191
    The reason its uneven is bc i have not got a screw to fasten the other side
    Sep 2013
    360
    Anything moving on this yet?
    Nov 2020
    Mars
    191
    Very slowly. I need to reprint the shackles and sand the bed part down a bit. I put to much paint on. I will update you soon. School has been kind of busy.
  33. #33
    Sep 2013
    360
    Ah, ok..was just curious how your paint turned out
  34. #34
    Nov 2020
    Mars
    191
    Finished painting everything almost just need to reprint the shackles
