    Mar 2021
    14
    Is the high speed needle at 2 turns out still within "normal settings" ?
    After break in (with 33% nitro) at about slightly more than 3 turns out on the high speed needle.
    Still see blue smoke at full throttle and doesn't sounds like it is going to stall or have any other indicators of being too lean.
    Does it change drastically below 3 turns, where it can cause damage?
    For example, is the high speed needle at 2 turns out still within "normal settings" ?
    Thank You.
    14,360
    If you are up in the mountain tops then maybe. That is not normal. I've found where I live that it is no more than maybe half a turn either way from stock settings before it is too much or too little fuel.
    Mar 2021
    14
    @Double-G,
    Okay, no normal conditions....it just seems like it has so much more to go, but its already more than fast.
