Results 1 to 10 of 10
    Dec 2020
    spain
    6
    slash diffs in a t.maxx?
    hey ive been trying to build a diff here for a custom t maxx im working on,im looking for something strong as ill be running a .28 engine with centre diff,does anyone know if the slash diffs fit into the t maxx diff housing?,im curious if the traxxas diffs are interchangeable?,any help is much appreciated,thanks
    Dec 2003
    Dekalb, IL
    3,770
    It looks like the current t-maxx does use the same internals as the revo, so you can use the older brushless revo internals at least.
    The diff cup with the metal plates in it (3978), the spider gears with the i-bar (5382x). The ring/pinion/outdrives are the same (slash/stampede use smaller od outdrives).
    https://traxxas.com/sites/default/fi...20Assembly.jpg
    https://traxxas.com/sites/default/fi...r_100126_0.pdf
    Combine that with some alloy diff case halves and that's about as tough as your going to get without trying to mess around with 1/8th stuff.
    Dec 2020
    spain
    6
    Thanks a lot for that info man,yea im going to look into ordering the parts for one and go from there,so are the ring/pinion outdrives the same with all models except for the diameter of the od?
    ive seen these going cheap and was wondering if i could use any of the parts or if they would fit the t maxx casing?
    https://www.aliexpress.com/item/4000...c001axMKj&mp=1
    Dec 2003
    Dekalb, IL
    3,770
    I haven't messed with a t-maxx in 15 years. I just looked at the parts explosions to give you a hand.
    I know back when I had one, the diff cups with plates and the i-bar didn't exist. Without running alloy diff cases and cups, I couldn't keep a diff alive in my BB maxx to save my life, even with a weak big block. Even with that, they still didn't last long, but I wasn't aware of diff shimming like I am now. May have made a difference since I had alloy cases.
    But my BB revo holds up way better than it ever did... after replacing the trans gears with RRP steel anyway. As my revo diffs go out, I rebuild them using the cups/internals I suggested for your tmaxx.
    This is what I had back then, was a grey engine 2.5 t-maxx:
    All the parts are different now. Guessing they are a lot better.
    Dec 2014
    Adirondacks
    2,837
    Be careful trying to use Slash differentials. The brushed model has a different gearing than the brushless model.
    Also depending on front or rear, the pinions are different in the Slash.
    Why are you wanting to use Slash diffs in a T-maxx?
    14,348
    Dec 2003
    Dekalb, IL
    3,770
    I'd seen that before, but couldn't find it again.
    Would have saved me ordering the wrong outdrives for my stampede when I was upgrading the cups and adding the ibar internals.
    Thanks!
    14,348
    Thanks!
    I was happy to find it before changing out my Slash 4x4 rear diff to XO-1 spec. Checked the stock front last night and still in perfect condition.
    Dec 2003
    Dekalb, IL
    3,770
    Hoping mine make it through the summer running 4S 4074 2050kv through it in my slampede...
    Dec 2020
    spain
    6
    thanks for the info guys,ive jst ordered the hot racing diff gears,aluminum cups so hopefully these will do the job
