Results 1 to 4 of 4
    Apr 2021
    Rustler 4x4 vxl esc and motor upgrade
    Hello first time poster. I have a few cars 2wd rustler castle mamba x esc and 3700kv motor. Decently fast but want faster couple weeks ago I snagged a vxl 4x4 rustler. Today I won a erevo and my thought is to swap vxl-6s esc and 2200kv motor to 4wd rustler and upgrade esc and motor in erevo. If I ran 6s in the rustler what kind of speeds would I see for top speed runs also haven't found anyone specifically doing this with traxxas electronics. Tia
    Jul 2020
    223
    Quote Originally Posted by Zach5187 View Post
    Traxxas' main downfall IS there electronics, imo. But honestly i haven't NEARLY tried them all! I feel like they "throttle-down" their power systems, to make more user-"friendly", but in all my reading and personal VXL 3s (stock R4sty power sys) is they run HOT As heck!! (There's definitely a stronger word). Lol!
    This in turn, causes many MANY ove-heated, turned-in/warrantied/power-up-program-ed and thus more revenue, etc, etc. More "repeat business" even if its intentional mfg "fluke".
    Call me a conspiracy theorist! All of the theories which became realities, can no longer be called "theory", (in theory?) Bahahahaha
    I digress!
    My R4stler vxl noe runs HW ez-run Max8 esc with 4274-can, 2200kv motor, with i believe (currently), i run 17t maybe 19t pinion and 34-36t spur, (mod 1 for 1/8th scale torque handling-toughness) and live in NC where summer temps are average 92-99F, mixed with no less than 40 or 45% humidity, up to 100 percent humidity all summer (and most spring!) And usually running 75-90% asphalt, talon ext's, sledgehammers, PL street fighter, PL Badlands MX28 belted tires, or 2.2/3.0 SC wheel/tires. Motor never breaks 160F, ONCE it did, but i was TRYING to bash and giver'h-e-doublehockeysticks! I hit 164F...esc thermal protection for motor kicks on @250 or some crazy number! Lol i stick to 160 max. And tbh, i am NOT a fan of 6s power for R4sty....wayyyy too much, and because of the way i drive, i spend the whole pack on my roof lol
    Sent from my Pixel 3a using Tapatalk
    Mar 2021
    63
    6s in a Rustler..... 80mph/90mph. Just a guess. Broken parts.?? Yup.
    RC Turnbuckle Jr. olds97_lss's Avatar
    Dec 2003
    Dekalb, IL
    3,704
    You would likely need to upgrade your diffs to have the i-bar in them with the diff cup with metal inserts for the x-pin as well as your slider axles and probably the center shaft.
    I run 4S in my slampede (blx185-150A esc/4074 2050kv motor) and upgraded all of those things, but I upgraded most of that just to be able to run 2S and later 3S in it with how/where I drive and the tires I use.
    Even on 4S... the thing is a handful to drive with 3.8 LP MT tires on it. The rustler would be a bit lower CG, but I'd start with 4S and go from there, unless your after straight line speeds only.
    https://www.youtube.com/c/olds97lss
