Results 1 to 15 of 15
    Sep 2012
    Hammonton Nj
    1,365
    E Revo Paddle tires on Rear Only ?
    Is it ok to run just paddles in the rear ? The paddles and Backflips weight the same 300grams , I ll go down a few teeth on the pinion ,they are like 1/2 inch taller and wider , I just don’t
    want to blow out my diffs , I m still new to the 4x4 game , thanks Rob
    Sep 2012
    Hammonton Nj
    1,365
    Or should I just run paddles on front and rear ?, the Backflip LP tires are taped , The paddles are not
    Oct 2018
    424
    Run all 4 paddles. Having a larger diameter rear means it'll be pushing the front tires, causing steering issues. Had the fronts been slightly larger it would increase steering, like having overdrive in the front on a crawler. Having different size tires on either end would cause premature issues, though its not that bad if you're in low traction areas.
    Sep 2012
    Hammonton Nj
    1,365
    I would just run them in sand
    Dec 2014
    Adirondacks
    2,839
    Not sure how well it will work out running two different tires with different traction.
    Remember that the Maxx has a center differential. So you could/can run tires of different sizes and/or tread type. The center diff can compensate, but it would get a good workout.
    I would think that your rear tires (paddles) would get the most traction, with the front tires getting the least. Because of that the front will receive the most power and spin the most. And the back with the paddles would get the least amount of power and not be very effective.
    Sep 2012
    Hammonton Nj
    1,365
    I may just try as is for now and get two more in the future
    Oct 2018
    424
    Do just the fronts then. It'll be best in that situation. Can try rears just to see how it goes, but the front is where you want them.
    Dec 2014
    Adirondacks
    2,839
    Give them a try in the rears, then a try in the front. If it works out for you, that's great. If not then a see two more in your future, LoL.
    Jan 2021
    91
    I know on a real vehicle that would tear the drivetrain up , not sure about a r/c.
    Sep 2012
    Hammonton Nj
    1,365
    True, They are the exact same weight - But the rear diameter is about a 1/2 larger - Wish me luck !
    Sep 2012
    Hammonton Nj
    1,365
    Epic fail ! It really zaps the torque and power from the rear , it just wants spin the front tires , dont bother guys, maybe 4 2.8 sand paws is a better option , they are smaller for sure
    Dec 2014
    Adirondacks
    2,839
    Quote Originally Posted by Role View Post
    Can't say you didn't try! LoL
    At least you learned something. This little experiment shows you how the center differential works.
    Sep 2012
    Hammonton Nj
    1,365
    It felt like my battery has 1/2 dead , stick with similar tires guys
    Sep 2012
    Hammonton Nj
    1,365
    Well , these are just too much tire for the maxx , I geared down two teeth of the pinion and run 6s , the truck just feels sluggish to me , stick with something smaller guys, maybe the bigger 42mm motor may help
    Sep 2012
    Hammonton Nj
    1,365
